Flange Analysis ANSI Check: Material group ID maybe picked incorrectly from library
ADO system
1128426 |
1124006 |
673380 |
TFS system
1124006 |
1072137 |
1053801 |
955880 |
936789 |
905085 |
896029 | B31.1 Material Library: Thermal expansion data (Table B-1) was not updated in B311-12, B311-14 & B311-16 |
344919 | Base material for SA508-1A material specification is incorrectly set as Low Alloy Steel instead of carbon steel |
322624 | ASME NB: Allowable value for a transient with zero moment case and a non-thermal case is calculated incorrectly |
258618 | ASME NC/ND: B2r/C2r calculations incorrectly use reinforced branch mean radius for evaluating branch thickness tb |
139105 | Thermal bowing: "Instantaneous expansion coeff. for NS materials" is not used |
139101 | Absolute axial stress not used for calculating expansion stress for B31.3 (2012) |
139095 | Ce factor and exposure category is not retained in UBC wind profile dialog |
91835 | DNV 2012 ASD check does not take in to account maximum longitudinal stress |
89211 | Equivalent temperature rise dt is calculated incorrectly for HDPE pipes |
