The following enhancements and defects have already been requested:
ADO:
Add BS EN 13480-3, 2020
Development Project: TBD
TFS:
Add BS EN 13480-3, 2017
Add Fatigue analysis to EN13480
Allowable value may be set to zero for user defined expansion combination with thermal cases from more than one analysis set
Add EN13480 : 2012 piping code update
EN 13480 2010 is the 4th addenda to the 2002 code.
Development Project: 9.6.1 (scheduled March-April 2014, barring any testing issues)
Add EN 10253 type A and B piping components for use in EN 13480
Description:
Add options to enter type A and B piping component (i.e. bends, Tees, reducers, etc..) per EN 10253-2 for use in a model with piping code = En 13480.
Piping Codes Enhancements & Defects
