Format (Node/Combin) | Displacement Scale |
Force (Global/Local) | Range reduction factor |
Include axial force | Weld efficiency factor |
Overwrite output file | Y Factor |
Use nominal thickness | Design factor F |
Use nom. thk. for Hoop | Temperature derating factor |
Set SUS SIF =1 no bends | Design Pressure factor |
Single SIF at point | Minimum Stress Ratio |
Set Sus/Occ SIF = 1 | Hoop safety factor |
Set Sus/Occ = 0.75i | Long. safety factor |
Include torsion | Shear allowable factor |
Single SIF at tees | Total allowable factor |
Apply all K-factors | Interm. stress points |
Include results desc | No. of thermal ranges |
Include bend ovaling | Include Max Range comb |
Include hoop bending | Use code case 178 |
Direct Shear (N/R/A) | Include Axial,Pcase in Sustained |
Total stress(Oct/Max) | Use Alt Occ Allowable |
Use Rest. Long Code eq | Use Avg Sm allowable |
Apply modulus ratio | Apply circ w factor |
Apply tee summation | Use theoretical Sec Mod |
Sustain Margin (Y/N/E) | Long. Pressure (P/A/M/N) |
Use min. sustained margin | Show rigid tee stress |
Use g's for acceleration | Modal/Timestep tee summ |
Use min. tee allowable | Press. Corr. For User SIF |
Digits after decimal | Apply CSA N289.3 criteria |
Use Resultant Method |
Additional Fields for B31.3 2010 edition.
Additional Fields for B31.4 Offshore and B31.8 Offshore.
Additional Fields for CSA-Z662 Offshore.
Additional Fields for SNiP 2.05.06-85 Oil & Gas.
Additional Fields for EN13480 European code.
Additional Fields for ISO 14692
