| Version(s): | 2004, XM, & V8i | ||
| Area: | Settings | ||
| Subarea: | |||
Under Tools> Model options> Result, "Range reduction factor" and square are in grey, I read the "help" contends, but it can not help me change the grey area to black. now , we use ASME B31.3, the "Range reduction factor" is very important to our work analysis. Is there another area offer user to define this parameter?
1. Open your model in AutoPIPE
2. Select Tools> Model Options> Results> See "Range Reduction Factor is grayed out. Press Help button on this dialog screen.
3. Select Hyperlink for "Range Reduction Factor"
4. Select See Also: "Range Reduction Factor tables" hyper link (see above image).
5. Select "ASME B31.3 Range Reduction Factor" hyperlink, and read entire page, especially the Notes.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
