| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Save | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
Suppose that AutoPIPE Model A is open, run the Analysis, and review the results in the Results Grids. Now, using the "Save As" command, save model A as Model B. In Model B, modify a support (i.e. convert spring support to a V-stop), now open the Results Grids.
When looking at the Results Grid in Model B, the Results Grid data is the same as that found when reviewing Model A results. However, close the Results Grids, press Analyze all for Model B, and re-open the Results Grids. The data has been updated accordingly. why the change in results grids?
This issue is repeatable in AutoPIPE V8i 09.02.xx.to AutoPIPE V8i 09.06.00.xx and lower
When AutoPIPE first introduced Network File Access (AutoPIPE V8i 09.02.xx.xx), when using the File> Save-As command, the program saved a copy of the results file to the new model name, unless the analysis results was deleted or refreshed as mentioned above, the older results would be shown. This issue is being addressed in the next release of the program, AutoPIPE V8i 09.06.00.17 and higher.
