Comments, Questions, and Answers AutoPIPE Result Grids:
- Ability to export data to MS Excel or MS Access
- On the Code stress tab some of the combination results has the wrong units, example: from Result> Code Stresses> note units for PE Ring Def are inches.
- Input / Results grid are missing, reset location
- Can user control which columns to print in the "Reult Grid" mode? All I am interested to see in the print out is the first eleven columns (SEG to GlobalFR inclusive). Can it be done?
- Results grids, Code Stress Tab is blank
- Select Results> Code Stress> Stress, the color map for the Stress range is displayed with a floating dialog displaying information, What is Sustained (Max) and Rest-Fun (Max)?
- How to calculate the values for all the calculated values on the AutoPIPE Results Grid> Code Stresses tab> i.e. Stress, Allowable, Pressure, Bending, etc..
- Why is there no moment column on the Results grid - support tab?
- After using Save-As command, after some modifications, pressing Results grids directly displayed the results from the original file and not the updated file newly created, why?
- What does the Local 1, Local 2 and Local 3 columns mean on the Results grid support tab?
- Are the Results grids results in Local or Global coordinate system when using AutoPIPE?
