| Version(s): | CONNECT Edition & V8i | ||
| Area: | General | ||
| Subarea: | Preferences |
I am suddenly experiencing issues, errors and odd behaviors in OpenBuildings Designer. For example:
For intermittent odd behavior we recommend that you first try regenerating your local \prefs files:
1. Close OpenBuildings Designer.
2. Use Windows Explorer to browse to your \prefs folder, by default found under C:\Users\your.name\AppData\Local\Bentley\OpenBuildingsDesigner\10.0.0\xxxxxxxx\. This location is defined by the configuration variable TFDIR_PREFS.
You can also check the preferences location by choosing File > Settings > Configuration > About Configuration in CONNECT Edition, or Workspace > About Workspace in V8i.
3. Rename the \prefs folder to "\123prefs" or similar. Make sure to change the characters at the beginning of the name, otherwise OBD might sometimes use the older one instead of generating a new one.
4. Restart OpenBuildings Designer.
This will generate a new set of preference files which may help resolve these random issues.
OpenBuildings - Unable to locate Prefs folder for OpenBuildings Designer (service-now.com)
OpenBuildings - Changing the location of prefs folder on OBD - Knowledge Portal
External Links
