OpenX Designer: Corridor Performance Optimization Strategy
This article details best practices for optimizing OpenX Designer corridor modeling workflows. Implementing clipped terrains, controlled template drop intervals, efficient constraint hierarchy, minimal reference attachments, and selective rule processing significantly reduces re-processing times and prevents performance bottlenecks.
1. Primary Corridor Processing Drivers
2. Active Surface & Terrain Control
3. Template Strategy & Drop Intervals
4. Constraint Selection Hierarchy
Choose constraint types based on processing efficiency:
  1. Parametric Constraints (Fastest): Most efficient for scaling dimensions, cross slopes, and pavement widths over long distances.
  2. Point Controls (Moderate): Powerful for targeting geometry but processing overhead increases significantly when targeting linear elements containing high vertex counts.
  3. Horizontal Feature Constraints (Slowest): Requires continuous spatial checking; use sparingly.
  4. Project to Surface Constraints: Use Project to Surface template constraints instead of vertical point controls when matching existing ground elevations.
5. High-Vertex Surveyed Edge Workflow
6. Corridor Clipping Best Practices & Limitations
7. Rule Deactivation & Bulk Editing
8. Graphics Reduction & File Cleanup
9. Target Aliasing & Reference Management
10. Summary Checklist for Corridor Performance
Performance Area
Recommended Practice
Practice to Avoid
Terrain Target
Target a small, clipped terrain model
Targeting large, full-project terrain surfaces
Surface Activity
Leave terrain inactive until end-condition setup
Keeping terrain active during backbone setup
Use Parametric Constraints & Project to Surface
Using Vertical Point Controls on high-vertex lines
View Cleanup
Close Dynamic Cross Sections before file exit
Exiting DGN files with dynamic views open
Rule Processing
Deactivate rules during bulk corridor edits
Allowing live re-processing after single edits
