Summary
When generating End Area Volume (EAV) reports, users may notice additional stations appearing in the output that are not part of the selected Named Boundary Group. These extra rows typically occur at locations where the mass ordinate equals zero, which can make the report appear incorrect or confusing.
This behavior is expected and can be controlled through the report XSL configuration.
Description
The XML output generated for End Area Volume calculations intentionally includes additional stations where the mass ordinate is zero. These stations are included for calculation completeness and are labeled differently than the stations coming directly from the Named Boundary Group.
Specifically:
By default, the delivered EAV report stylesheets include both station types, which is why these extra rows appear in the final report.
The following delivered XSL stylesheets include both station types by default:
Cause
The XSL templates in the delivered reports are configured to process both StationVolume and DerivedStationVolume nodes from the XML output. This results in extra rows appearing in the report table even when those stations are not part of the Named Boundary Group.
Resolution / Workaround
If you want the report to include only the stations defined by the Named Boundary Group, you can modify the XSL file to exclude the derived stations.
Steps:
<xsl:template match="StationVolume | DerivedStationVolume">
<xsl:template match="StationVolume">
After this change, the report will only include stations that come directly from the Named Boundary Group, and the extra zero–mass-ordinate stations will no longer appear.
Additional Notes
Keywords
End Area Volume, EAV report, Mass Ordinate, Named Boundaries, DerivedStationVolume, StationVolume, XSL, OpenRoads reporting
