How to Insert Page Break in BRCM report templates
Product(s): Bentley Raceway and Cable Management
Version(s): 10.03.00.25
Environment: N/A
Area: Output Manager Reports
Subarea: Edit Report Template
BRCM reports manager provides a variety of reports for cable and raceway. The reports are categories into two parts as Conceptual Design and Detailed Design. BRCM Connect Edition is having feature edit the template of the report and customize the report as per requirement. This WiKi article provides procedures to be followed to make each report's contents on a new page.
Steps To Accomplish-
1. Go to Output Manager and select the report required to be edited. Make sure that related resources selected and click on the Edit Report Template icon at the left of the output manager dialog. Report designer dialog will open.
2. In Report Designer Dialog. Click on GroupFooter1 and goto Property Grid. In Property Grid there is a section Behavior, in this section click on the drop-down arrow of Page Break and select ‘After the Band.’ Save this report template by clicking the save icon.
3. Below is the sample report seen after following these steps:
Original Author: Vikrant Kale
