| Applies To: |
Product(s): |
RAM Structural System |
Version(s): |
Any |
Area: |
General; Import/Export |
Below is the basic Python code for a project using RAM DataAccess. An image of the development console and the plain text are included. This would be the main.py file.
import win32com.client as win32 try: # Create an instance of RAMDataAccess DataAccess = win32.Dispatch("RAMDataAccess.RamDataAccess1.1") # Get IDBIO1 interface and then call the GetIniFilePath() method # looking at RAMDataAccess.tlh we see that IDBIO1_INT = 10 dbio = DataAccess.GetInterfacePointerByEnum(10) # use it..., lets try the GetIniFilePath() method iniPath = dbio.GetIniFilePath() # print it print(f"Ini path: {iniPath}") except Exception as e: print(f"Error: {e}") # Clean up COM object del DataAccess
What is RAM DataAccess? [TN]
