MicroStation CONNECT, 2023 - 2025 Frequently Asked Questions
Which operating systems are supported?
What are the minimum hardware requirements?
Is the V8 DGN file format sustained in this release?
Yes, the V8 DGN format remains unchanged for all supported versions of MicroStation.
Can I install MicroStation 2025 on the same machine as an older version like CONNECT Edition or MicroStation V8i?
From the release of MicroStation 2023 onwards, Side-by-Side installation will be supported for Major Releases. Minor Release updates will upgrade a Major Release and a Major release and Minor Release will not be able to sit Side by Side. Users will have the ability to run multiple major releases MicroStation on the same machine. Installation of MicroStation 2023 and onwards will by default occur alongside any previous installations. Removing previous versions of MicroStation will require a manual uninstall.
What versions of ProjectWise Design Integration will be supported by this release?
Check the ProjectWise Version Support Matrix.
What is the easiest way to find the tools I need in this new version?
After familiarizing yourself with the layout, be sure to use the integrated search found in the upper right corner of the interface to find any command quickly. You can also launch commands directly from the search bar.
What versions of Autodesk ® RealDWG  are supported?
The MicroStation 2025 ships with Autodesk ® RealDWG 2026 which supports DWG versions 2018 – 2026.
Which object enablers are supported?
Any object enablers that are compatible with Autodesk ® RealDWG  2026.
Are my existing Workspaces supported?
MicroStation 2025 adds new concepts to the application's configuration.  Please check the product documentation for details on how to upgrade existing Workspaces to a CONNECT Edition configuration.
In particular the Configuration topic as well as the WorkSpaceSetup.cfg Configuration File topic should be consulted.
How do I migrate my V8i user interface customizations to this version?
All of your exiting toolboxes, tasks, cursor menus and custom application user interfaces from MicroStation V8i are supported in this version. We have also provided easy migration tools to upgrade your existing V8i customizations to the new ribbon and ribbon panel popups when you chose to do so. We estimate that 80-90% of your user interface customizations are immediately useful in this version.
Here is a complete list of what V8i user interface concepts are supported in this release with no additional effort
Is MicroStation BASIC still supported?
MicroStation no longer includes MicroStation BASIC, it is suggested that existing MicroStation BASIC macros be rewritten as VBA to be used in the new version.  The MicroStation VBA help documentation provides a good reference for VBA creation, and we have included some of the primary differences between the two languages below to help you get started. Additionally, the Bentley Institute offers several MicroStation VBA Programming courses which provide in-depth instructions for customizing MicroStation with VBA
How do I migrate MicroStation BASIC macros to the new version?
MicroStation BASIC macros can be migrated to the new version with one of the following methods:
What is the activation period for supported version of MicroStation?
MicroStation will run without a license for 7 days as an evaluation period.  After being licensed, it must communicate with a license server at least every seven days to continue operation.  In fact, all Bentley desktop products are now standardized on a seven-day activation period.  This ensures better, more accurate reporting and helps to make sure a company does not inadvertently exceed their license count.
For those customers running disconnected or mobile solutions the best option for uninterrupted operation is to check out a license.  A checked-out license can run up to a year without connecting to a license server.
How are new element types such as tables and parametric cells handled in previous editions of MicroStation?
New element types are generally displayed in previous versions of MicroStation but remain read-only in that they cannot be edited or moved.  However, they can be copied or deleted.
Are two licenses used if I start MicroStation 2025 and CONNECT Edition at the same time?
Although two usage records are recorded, one for each product, only one usage is calculated as it is run on one unique machine.  So, the behavior is the same as if two instances of the same version were started at the same time.
Other Language Sources:
Français
Español
Deutsch
