| Version(s): | 2004, XM, & V8i | ||
| Area: | License | ||
The following is displayed when I run the application:
Errors:
151 License: Design Code required isn't part of your license (ASME).
334 Tubesheet: Design code required ins't part of your License (ASME).
Please confirm the following:
1. The correct codes are available on your license server. File> License Management Tool> License Checkout tab. Is the correct license code shown in the listing? If not listed, contact Bentley Licensing team for correction.
Note: AutoPIPE Vessel Enterprise covers all codes. If using only Vessel Enterprise license, Add-on codes may show as grey (see image below), this is OK.
2. In side AutoPIPE Vessel, select File> License Settings> check On " Show license at startup". Close the program and restart the program, when the AutoPIPE Vessel Licensing dialog appears press the OK button to start using the program.
