| Version(s): | ALL |
| Area: | Error message |
| Date Logged & Current Version | June 2018 40.06.00.07 |
287 FLANGES: error in formula [40*bd] for gasket according to AD B7. .. messages appears in AutoPIPE Vessel, why?
Suggest to confirm that there are not any inconsistent data in the model, see below:
In this example above, the external diameter of the gasket was found to be smaller than the internal diameter of the flange.
