| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Error | ||
| Subarea: | |||
The following occurs when I perform the Strength Calculations:
Errors:
404 Flange xx.xx seating pressure less than or equal to zero.
How to fix it?
Typical reason for this message is that model as selected the wrong choice of gasket material - example: elastomer rubber and near zero seating pressure as shown below:
Fix for this particular model was to modify with the same type of gasket for all the flanges.
