| Version(s): | V8i |
| Environment: | N/A |
| Date Logged & Current Version | Dec. 2016 40.02.00.08 |
The following message appears in AutoPIPE Vessel, how to avoid it?
411 Nozzle AP (pad): allowable stress at temperature missing
412 Nozzle AP (pad): exceptional ambient allowable stress missing
Here is a suggested workaround which has worked:
D. Click ok, it will pop up a message as follows
E.Click OK, then click on ‘Cancel’ on the Nozzle Neck dialog box
F.Then run the file
This should solve the problem
