| Version(s): | All |
| Environment: | N/A |
| Date Logged & Current Version | Dec. 2016 40.02.00.08 |
The following is displayed when opening a model in AutoPIPE vessel:
Starting Exporting DGN
Fail to open DGN file C:\Program files\ EuResearch\Data\Finmod\up_bib.cel.. Error Code = 77832
Error!!! Abnormal Termination of @d-DgnExport.
Why does this happen and how to avoid?
When the user installed Microprotol, the Customizable Database Files Path
was "C:\Program Files\EuResearch\Data\Ficmod" (by default) in the property tab "Preference".
And also the user declared the Customizable Database Files Path in the data file .emvd
in the vessel properties ( see below ). it was not useful.
When the user starts AutoPIPE Vessel, AutoPIPE Vessel checks if the Customizable
Database Files Path declared in the data file exists.
The Customizable Database Files Path is declared in the data file .emvd
<SpecificFicmodPath>C:\Program Files\EuResearch\Data\Ficmod</SpecificFicmodPath>
There is suspicion that this user uninstalled AutoPIPE Vessel, so the folder "Ficmod" was removed.
systemname.emvd ( if the Customizable Database Files Path in the data file exists )
Syytemname.emvd ( if the Customizable Database Files Path in the data file does not exist).
AutoPIPE Vessel displays a message indicating the Customizable Database Files Path in the data file does not exist and will be removed in the data file .emvd. The user will save the data file .emvd, so the Customizable Database Files Path will not be in the data file anymore
