28. Results are different for nozzles when using AutoPIPE Vessel instead of Microprotol
Answer:
One change that may answer the discrepancy between the models is that the calculation of the weight of nozzle necks has been optimized in September 2012 (v33.0.7.3) to consider the intersection of the neck with the shell (height difference depending onĀ  the inclination and eccentricity of the nozzle).
Before the nozzle neck was considered as a cylinder of constant height.
