02. How to open a specific component calculation report from the option "Show Selected Report Calcu
Answer:
The component calculation details are located in subreport folder, follow the link below for more details:
http://communities.bentley.com/products/pipe_stress_analysis/w/pipe_stress_analysis__wiki/24058.subreport-location
In order to resort the issue above do the following:
1. Is the button enabled or disabled (greyed):
If the button is disabled:
If the button is enabled but when it click it does nothing:
In both cases:
To watch the on-demand webinar "Maximizing AutoPIPE Standard and Custom Reporting Capabilities", click here.
