| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Report |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
In code stress ratio plot, the maximum displacement was clearly shown as 379 at node point A05.
In the Stress Summary of an output report, the maximum displacement stress was reported as 195 at A00,
why the difference?
Confirm that "Limit results to highlighted points" is unchecked, before creating an output report.
The output report was only limited to the highlighted points, if there are no highlighted points than the report is blank.
Avoidance #1: highlight some or all node points in the model before creating an output report
Avoidance #2: Disable "Limit results to highlighted points".
Using both options will have the same affect, report will now contain the correct Max values per selection set highlighted or entire model, see below for example
See online help for complete details on this option.
"Result Summary" sub-report using Results> Output Report
