Interactive Guide to Licensing AutoPIPE - Step 6a: Find your Select Server and Site activation Key i
The most import setting in LMT is the "Server Name" and "Site Activation Key". These fields can be found after opening LMT, select Tools> Options> the following dialog will then appear:
Use one or more of the following options to get this information
Server Name:
Option #1:
For Hosted licenses, Server Name = selectserver.bentley.com
For Non-Select licenses (click here), Server Name = productactivation.bentley.com
Option #2:
For Deployed server, contact your IT department or Bentley On Site Admin
How to Request an updated license for a Deployed Select Server
Site Activation Key:
Option #1:
The primary location for this information is your company's designated "Bentley On site Admin(s)". This person(s) would have received an email from Bentley containing this information.
Option #2:
ONLY If you are an Bentley On Site Admin, use the procedure here.
Option #3:
Contact Bentley Licensing group by phone or by submitting a Service Request directed to the Licencing group.
Note:
Due to security issues, ONLY person(s) listed as an Bentley Onsite Admin can request the Site Activation key be sent to them by email. All others will be provided a list of Bentley Site Admins with which they can contact directly for that information.
