| Version(s): | 11.x and lower | ||
| Area: | Licensing | ||
The following appears when starting AutoPIPE
Warning
W2018-11: Not authorized for Standard edition.
Contact Bentley for authorization. Converting to DEMO.
OK
Warning
W2018-12: Not authorized for Plus edition.
OK
Warning
W2018-16: Not authorized for Nuclear edition.
OK
The problem is Licensing. Based on the settings in LMT, you are not authorized to use the indicated edition (i.e. Standard, Advance, and/or Nuclear) .
Select the hyperlink in the table below:
The means that a valid license for AutoPIPE Standard edition is not available in LMT. The Application will revert to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for, click here |
The means that a valid license for AutoPIPE Advance (aka. PLUS) edition is not available in LMT. The Application will revert to Demo Mode. Select here to figure out what AutoPIPE Edition user is Authorized for, click here |
The means that a valid license for AutoPIPE Nuclear edition is not available in LMT. The Application will revert to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for, click here |
If you have the correct license set up in Bentley Licensing Tool, and you are getting the message, please update the machines with the latest Connection Client.
Interactive Guide to Licensing
