03. What are the local axis directions when +Z-axis is vertically up in AutoPIPE?
Product(s):AutoPIPE
Version(s):ALL;
Environment: N/A
Area:
Date Logged
& Current Version
Dec. 2016
10.01.00.09
Problem:
 Local Axis directions when Y-axis is vertically up:
Local Axis directions when General Model Options, Vertical axis directionZ-axis will be identical to above orientation.  Again local axis is not dependent on General Model options "Vertical Axis direction" setting. This is by design.
See AutoPIPE help:
General Model Options Dialog
