| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | message |
| Date Logged & Current Version | Nov. 2020 12.04.00.13 |
The following message dialog appears when trying to view a Stress iso drawing in OPIM.
Text Node Editor:
Invalid entry in 'node2da.txt.
Reason: Duplicate 'Text Node No.' assigned for different attributes.
Ok
Why doe this occur and how to avoid it?
This is a known issue when using OPIM 10.06 and lower. This was fixed in OPIM 10.07 and higher.
Avoidance, change the computer regional setting decimal symbol from comma to decimal.
