| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Date Logged & Current Version | May 2015 09.06.02.06 |
Why does the Analysis summary report not match the Data in the model?
Example: see the model Temperature values:
However in the Analysis Summary, the temperature values are printed in the report as:
Why and how to fix?
The printed report values that are enclosed within the "< >" brackets are not temperature data from the model but rather the Load Combination Description Automatically generated / Manually entered under the Tools> Load Combinations dialog
Analysis Summary sub report issues:
