02-01.b: Issues with Importing *.NTL file into AutoPIPE
Questions related to imported NTL files
  1. All material names set to NS (non-standard)
  2. CORA and MTOL from the PIPE command card does not appear to be properly interpreted
  3. Fluid density factor is always set to 0.00
  4. After Importing an file, cannot modify valve tag names
  5. NTL File Version per AutoPIPE Version
  6. Determine the reason an imported NTL file led to program aborting or crashing
Error messages in *.MSG file
  1. *** ERROR: CANNOT PUT REDUCER AT THIS POINT. VALVE IGNORED
  2. *** ERROR: CANNOT PUT VALVE AT THIS POINT. VALVE IGNORED
  3. *** ERROR: INPUT UNIT FILE NOT READABLE
  4. *** ERROR: INVALID DIAMETER GIVEN. PIPE IGNORED
  5. *** ERROR: INVALID THICKNESS GIVEN. PIPE IGNORED.
  6. *** ERROR: MATERIAL FILE NOT FOUND.
  7. *** ERROR: NEAR POINT TYPE IS INVALID. RIGD IGNORED
  8. *** ERROR: ROTA POINT NOT DEFINED. WGT IGNORED
  9. *** ERROR: SIF POINT NOT DEFINED. SIF IGNORED
  10. *** ERROR: TEE POINT NOT DEFINED. TEE IGNORED
  11. *** ERROR: UNSUPPORTED OR UNRECOGNIZED ELEMENT TAG
  12. *** ERROR: WGT POINT NOT DEFINED. WGT IGNORED
  13.
Import and Export
