| Version(s): | ALL |
| Area: | Install |
| Date Logged & Current Version | June 2018 40.06.00.07 |
Do I have to uninstall Microprotol before installing AutoPIPE Vessel?
AutoPIPE Vessel will install to a new folder location and therefore, No, you do not need to uninstall Microprotol before installing AutoPIPE Vessel. You can have both applications on the same computer at the same time.
