Q. How to Set the Default Material Database into AutoPIPE Vessel?
User the following steps:
    1. Select File > Preference to display the Preference Properties dialog.
    2. Select the Default Path tab.
    3. From the Material Database path and name field, press Browse to display the Open dialog.
    4. Navigate to the appropriate database file (.emdm), then press Open.
    5. Press OK to close the Preference Properties dialog.
The default material database is now set. From this point forward, AutoPIPE Vessel defaults to use this material database.
How to add a new material into AutoPIPE Vessel
1. Version 42 and higher
2. Version 41 and lower
How to Load a Material Database
Support Solutions and FAQ's
Bentley AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
