| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | April. 2021 12.05.00.16 |
When using AutoPIPE Japanese version the results are printed in Japanese language. Is there a way to convert the results so they are printed in English language?
Maybe, use the following instructions:
1. Close all AutoPIPE windows that are running.
2. Go to installation directory which is by default is “C:\Program Files (x86)\Bentley\AutoPIPE CONNECT v12\”
3. Locate batch file “chmsg_us.bat” like below
Note: If chmsg_us.bat and chmsg_jp.bat files are not present then stop here. NO, one cannot changes the printed report language.
4. Run the file using administrator privileges
5. See output below
6. Now run AutoPIPE.exe.
7. To convert it back to Japanese use chmsg_jp.bat
Bentley AutoPIPE - Japanese version
