| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Note message |
| Date Logged & Current Version | April. 2021 12.05.00.16 |
The following note message appears when using AutoPIPE:
* * * W A R N I N G - MODEL * * *
Note: Material warnings for low temperature properties have been suppressed for pipe Ids listed below.
Expansion data will be extrapolated, other data will use last value in material library.
This may not be permitted by the selected piping code.
Why and how to avoid?
Simple, as the message indicates, the listed material properties has the following option enabled:
Suppress low temp warnings
or
No LT Warnings
By turning this option off will remove the waring from the Consistency check report. Otherwise, leave the option enabled and understand that it is a reminder to the users.
