| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Install | ||
| Date Logged & Current Version | Jan 2019 12.00.00.14 |
How do I Install Bentley AutoPIPE CONNECT v.12.05 - 12.00.?
Navigate to the *.EXE file downloaded using the download procedure.
Double click on the *.EXE file (ex. ap12000014en.exe) to start the installation process.
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient. Highly recommended that all applications are closed during the installation process. On average it will take no more 15 min to install everything (updating from AutoPIPE 11.04.00.10 takes an average of 4 min),
See Movie below, press on box located in lower right corner to enlarge video to full screen mode:
@ 30 sec - User selection of software to be installed with AutoPIPE
After clicking Finish button, AutoPIPE readme file will be displayed, click here for details of this file.
You are Finished !!!
AutoPIPE has now been installed:
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log mentioned above
Install any Dependencies that were also downloaded (typically double click on the EXE files that were downloaded (i.e OpenPLANT Isometric Manager, ProjectWise, etc..).
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Before starting AutoPIPE, continue to STEP #3: Set-Up Licensing
Download, Install, and License AutoPIPE CONNECT 12.00.xx.xx and higher
