| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Area: | Error Message |
| Date Logged & Current Version | June 2020 12.03.00.17 |
The following message appears when using AutoPIPE Nozzle,
APNozzle
Run-time error '713'
Class not registered
You need the following file to be installed on your machine.
MSSTDFMT.DLL.
OK
Why and how to avoid it?
MSSTDFMT.DLL a DLL (Dynamic Link Library) file, developed by Microsoft, which is referred to essential system files of the Windows OS. It usually contains a set of procedures and driver functions, which may be applied by Windows.
MSSTDFMT.DLL file, also known as Microsoft Standard Data Formatting Object DLL, is commonly associated with MSSTDFMT Object Library. It is an essential component, which ensures that Windows programs operate properly. Thus, if the msstdfmt.dll file is missing, it may negatively affect the work of the associated software.
Since you are seeing this message, your computer system is missing the aforementioned DLL. Bentley is not able to distribute this software. Therefore, user can copy it from another machine within the organization or search the internet for a trustworthy web location to download the file from. However, before downloading consider the following, go to Web page here, and review the following numbers that may resolve your issue: 3, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15.
Downloading Method:
Search the internet for a trustworthy web location to download the file from (example here)
Note:
1. Make sure to download the correct DLL for your version of Windows (ex. 10, 7,etc..) and system type (ex. 64 bit, 32 bit).
2. You may need administrator access to perform the steps below, contact your IT department for assistance.
After downloading the file (unzip if necessary) and place the file into the appropriate windows folder:
32 bit system type:
C:\Windows\System32
64 bit system type:
C:\Windows\SysWOW64
Next, start the command line as an administrator in Windows by pressing Win key on your keyboard and typing "Command Prompt" in the search field, then - right-click on the result and select Run as administrator.
enter the following at the command prompt
32 bit system type:
regsvr32 C:\Windows\System32\msstdfmt.dll
64 bit system type:
regsvr32 C:\Windows\SysWow64\msstdfmt.dll
the Following should then appear:
Restart AutoPIPE Nozzle and continue to use the program
09. Warnings, Errors, Crashed, Confirm Messages
