| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version | June 2021 12.06.00.48 |
How to turn off / remove north arrow from being printed on drawing
1. See which seed you are using by opening Isometric Manager Setting dialog
2. Take a backup of border file and then open border in OPIM
3. Remove the placeholder of North Arrow on top left
4. Save the drawing by File >> Save and File>>Save Settings
5. Open file “C:\ProgramData\Bentley\AutoPIPE CONNECT xxx\isoextractor\projects\project01\stress\Config\ node2da.txt”
6. Remove the nodes from 100 to 105 and save the file and close
7. Now generate drawing.
