| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Graphics |
| Date Logged & Current Version | July 2021 12.06.00.48 |
Tee arrows are not shown in AutoPIPE Model, why?
The 2 most popular reason and workarounds are:
1. The Show Tee Arrows command on the Views Settings dialog is turned OFF.
Workaround:
Turn Show Tee Arrows command On. See AutoPIPE help for command location and details of the feature.
2. There is a known OpenGL graphics display issue.
Workaround:
Change to a different Graphic display (ex. Single Line View, Wire-Frame View, Solid Model View) and back to the original setting:
Example, note that the display is Wire-Framed mode, change to Solid Model mode, and than change back to Wire-Framed mode again.
If this does not resolve the issue, check that your graphics card supports OpenGL. By performing procedure to test your graphics card for running AutoPIPE and send the results for review to Bentley.
