| Product(s): | AutoPIPE Nozzle |
| Version(s): | V8i |
| Environment: | N/A |
| Area: | Report |
| Date Logged & Current Version | Aug. 2016 08.11.08.26 |
Local Axis system load values do not appear to match WRC Axis system values in AutoPIPE nozzle output report?
AutoPIPE Nozzle output reported values are correct.
Note the images that show the axis directions, confirm axis directions to be:
Thus:
Note that the forces are straight forward but the Moments are a little more involved to understand. Let us look at the following example of the X-axis moment.
See WRC107 Axis vs Global axis
a. Look at the Global X-Axis = -X point vertical Up
b. using right hand rule, and looking at the axis from the arrow end, understand that the moment is rotating in a CCW (Counter Clock Wise direction) about the -X axis.
c. Per WRC 107 axis, flip your right hand in the direction of the +Radial, P direction, Vertically down, while still looking at the moment direction from the same point of view as above, tail end, now the moment direction about the X axis direction are CW (clockwise)
Therefore the Radial,P moments are -(global Axis).
OR, Global MX moments (+5005) = -ve WRC107 Radial, P = - (+5005) = -5005.
Using the same image above
a. Look at the Global Y-Axis = -Y point towards the nozzle.
b. In order to match the moment and pointing in the +Y axis direction must use Left hand rule
c. Again, looking at the axis from the +Y axis end point arrow end, understand that the moment is rotating in a CW (Clockwise direction) about the +Y axis.
c. Per WRC 107 axis, flip your left hand in the +VC axis direction, towards the nozzle, while still looking at the moment direction from the same point of view as above, tail end, now the moment direction about the Y axis direction are CCW (Counter Clockwise)
Therefore the VC moments are -(global Axis).
OR, Global MY moments (+4913) = -ve WRC107 VC = - (+4913) = -4913.
a. Look at the Global Z-Axis = +Z shell axis pointing away from the nozzle.
b. In order to match the moment and pointing in the +Z axis direction must use Right hand rule
c. Again, looking at the axis from the +Z axis arrow end, understand that the moment is rotating in a CCW (Counter Clockwise direction) about the +Z axis.
c. Per WRC 107 axis, flip your left hand in the +VL axis direction, towards the nozzle, while still looking at the moment direction from the same point of view as above, tail end, now the moment direction about the Z axis are CW (Clockwise)
OR, Global MZ moments -() = -ve WRC107 VC = - (+4913) = -4913.
Confirmation that AutoPIPE Nozzle's output reported values in sections 4 and 5 are correctly displayed.
Results Output in AutoPIPE Nozzle
