| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version | July 2021 12.06.00.48 |
The following appears in the model consistency check report:
* * * W A R N I N G - MODEL * * *
W2164-178:Tee header and branch data was corrupt and has been fixed on the following point
How to avoid it and fix it?
There is nothing to do except close the report and generate a model consistency report again.
The message should no longer appear, and the aforementioned node point data fixed
Warnings Messages displayed in AutoPIPE
