| Version(s): | ALL | ||
| Area: | Warning message | ||
The following is displayed when performing a model consistency check report:
W2143-37:Extremely high value for Displacement tolerance > 1000 detected in loadset
Why is that and how to Avoid it?
The problem is by running a non linear analysis there is another dialog screen that appears with some additional settings as shown below:
Press OK button above cause the following screen to appear:
If any of the tolerance values shown in the pink shaded area of the image above are too high the w2143-37 warning will be displayed in the model consistency check report. To remove this warning from the report, lower the tolerance as instructed (i.e < 1000), and press OK button to confirm the new value.
