| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning message |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
The following is displayed when performing a model consistency check report:
* * * W A R N I N G - MODEL * * *
W2143-7: The joint information of User SIF or flange will be ignored at following point(s)
Why is that and how to Avoid it?
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Bentley AutoPIPE> Command Reference> Insert Command> Piping Component Group> Bend Points> Bend Type> Pulled bend....
This warning was added in AutoPIPE 9.0.0.8 under the following enhancement TFS-E130802: Add "Pulled" option to bend type. The application would still use the User specified SIF values at the bend's Near and Far node points when calculating stresses.
Ignore message
or
Remove User SIF from all bend Near and Far node points when bend is set to Pulled.
