| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version | Jan. 2017 10.01.00.09 |
The following message appears in AutoPIPE:
W2164-93: The value of "Fluid Density Factor" is zero in following analysis sets
How to fix it?
From AutoPIPE help:
Enter the fluid density factor for the analysis set. The fluid density of the contents is multiplied with this factor. This factor is applied to gravity and seismic static load cases. Valid values range between 0.0 and 100000.0.
Again this is a warning alerting the user that the Fluid density value is set to 0.00. This may be ok for some user and some analysis. If not intended to be this way, suggest to open the Static Analysis Set dialog and confirm a value >0.00 (or Blank) is entered into the dialog field:
Message appears:
W2164-93: The value of "Fluid Density Factor" is zero in following analysis sets.
1
Open Static Analysis Set dialog and review Analysis Set #1:
Noticed that the value for Fluid density is blank (0.00).
Enter a valid value >0.00 (ex. 1.00)
