| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning Message |
| Date Logged & Current Version | June. 2017 11.00.00.22 |
The following warning appear when performing a Model Consistency Check or Design Check report. What does the following warning mean and how to resolve it?
* * * W A R N I N G * * *
W2182-26: Pressure rating on mating flange to a valve is not the same at point xxx
This is a warning message generated by the design check command to warn the user that there may be a problem with connected Flanges to Flanges or Flanges to Valves.
The user should review each occurrence of the warning to be sure that the correct pressure rated flanges / valves are connected and to update information as needed.
Again this is only a warning message for the user to confirm connected flanges / valves are using the correct settings. The message maybe ignored after investigation of related node point to be correctly modeled.
Note: There is an known issue in AutoPIPE CONNECT 11.0 where the W2182-26 message would still appear after confirmation mating flange ratings are a match. This will be fixed in the next release of the application (Defect 717975).
