| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version |
Nov. 2016 10.01.00.09 |
The following message appears when opening a model in AutoPIPE.
Warning
W511-67: Hydrotest load cases have been removed from existing
analysis sets and new hydrotest loadset has been added.
Please analyze the model again.
OK
Why and how to avoid it?
A new method of handling Hydrotest analysis was introduced in AutoPIPE V8i 09.06.01.10 and higher. Therefore when opening a model from a previous version into 09.06.01.10 or higher, a message will be displayed warning the user about the new enhancement.
As mentioned in the warning message above the previous Hydrotest load case (HY) was removed from all Static Analysis Load Case dialogs and was added as a new separate Analysis Set in AutoPIPE V8i 09.06.01.10 and higher::
See AutoPIPE help here for complete details on this new feature.
