| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Warning Messages | ||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 |
The following appears when analyzing a model in AutoPIPE:
Warning
W72-1: Some load cases were found in the model that exceed the
Standard edition limit of 5. You will be allowed to define load
cases beyond the limit but not analyze them. Analysis cases that
exceed the limit will be automatically deactivated by the program
unless you switch to the Advanced/Nuclear license (Tools/Setting/Edition).
OK
OR
W72-1 AutoPIPE Error Handeling
How to fix the model?
Look for missing load cases:
Example: T's, P's, U's, W's, E's :
Warnings Messages displayed in AutoPIPE
