| Version(s): | 2004, XM, & V8i | ||
| Area: | Warning | ||
The following appeared in the model consistency check report:
W726-2: Gap orientation has changed for guide at point XXX
Please review/update the gap data in the support dialog and press OK.
Navigate to the node point location mentioned in the warning message. For each guide support, modify the support (ie. double click the support, or Modify> Support command) so that the Support dialog screen appears. Review the gap settings, and press OK button when satisfied.
Warnings Messages displayed in AutoPIPE
