| Product(s): | AutoPIPE, |
| Version(s): | 2004, XM, & V8i |
| Area: | Warning Message |
The following is displayed in model consistency check report:
W726-7: Pipe diameter change without a reducer at point XXX
This warning message is displayed whenever there is a difference in pipe properties OD or wall thickness between two sucessive points in a model without a reducer.
Insert a reducer between the 2 different pipe properties.
As the designer, accept the warning as OK, and ignore it as the joint is correctly modeled. Insert a user Joint type / SIF added as needed.
This warning will appear when modeling a tee where 1 segment makes up both 1/2 the run of a Tee and the branch of a Tee, while the 2nd segment makes up the remanding 1/2 the run of a Tee.
This modeling technique is OK, however the warning will appear. Use one of the solutions below.
Solution #1: Make Tee using 3 different segments.
Solution #2: Make header 1 segment and branch a separate segment (use instructions on the following WIKI here).
There have been cases where the message is being displayed but the pipe appears to be using the same PipeID.
Understand how the pipe is broken into Segments:
Upon further investigation of the model input listing or Input grids, one can clearly see that different PipeID's have been specified.
Note, that each node point has a 2 sides, upstream and downstream. In this case the user was able to specify Segment C at the tee junction (ex. C00) with PipeID = 14.00P2 on both sides of the node point. However, at the junction between Seg C & D, the user was able to specify PipeID = 12.00P2 on the upstream side, and PipeID = 14.00P2 on the downstream side. Neither the user or AutoPIPE development was able to repeat this. Regardless the fix is simple. Select Segment C, use Modify> Pipe Properties over range, and select the correct pipe property, ex 14.00P2. The new model consistency check report no longer reports this node point with a W726-7 warning.
Warnings Messages displayed in AutoPIPE
