| Version(s): | 2004, XM, & V8i | ||
| Area: | Warnings | ||
The following is displayed in the model consistency check report:
W726-94: Zero weight valve found at point
How to fix?
Open the offending valve dialog screen, or navigate to the Input grid, Valve tab:
Notice that the indicated valve weight is missing.
For all valve Ratings = NS (Non-Standard) user must manually update the weight field.
Or
Select a different Valve Rating that will then retrieve the information from the valve library if available.
Warnings Messages displayed in AutoPIPE
