| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Calculations |
| Date Logged & Current Version | Aug. 2021 12.06.00.48 |
When I run an analysis with AutoPIPE V8i 09.06.00.15 with JSME S NC1-PPC Piping Code and edition = 2008, the following appear when I reviewing the results:
Warning
W831-11: Seismic level includes cases not analyzed
OK
Note
Seismic case number exceeds the number of defined Seismic load cases.
OK
However, it does not appear when using year = 2005. Why is that and how to avoid?
In addition, when reviewing the code combinations,
CODE COMPLIANCE COMBINATIONS
<Description>
Combination Category Method Case/Combination
**i*Szy{1} CSC Primary Abs sum *Pres
**B*Szy{1} CSC Pri+Occ Abs sum *Pres
where ** indicates that the combination includes unanalyzed load case(s)
See the following WIKI page: W831-11: Seismic level includes cases not analyzed
JSME S NC1-PPC Piping Code Calculation
