Note:
1. Download AutoPIPE Readme - click here
Version
Compatible with Bentley AutoPIPE CONNECT QAR v12 (Version 12.00.00.16)
Build Type
Connect Release Product
Operating Systems
Microsoft Windows (see System Requirements for specific details)
Language
English
Date
April 1, 2019
Software Verification Test Systems
The Bentley AutoPIPE Acceptance Test Set (ATS) provides the user with a recommended procedure for validating the integrity of the installed AutoPIPE 12.00.00.16 program.
Prior to any commercial or Quality Assured release, the accuracy of the AutoPIPE program is verified by the execution of Alpha Tests. These Alpha Tests consist of a matrix of test systems designed to capture key feature attributes related to numeric and functional processing. Each set of test outputs is compared to a prepared set of expected results (i.e. hand calculations, some other well-established computer program, etc.), and evaluated for acceptance. The test matrix has been developed, verified, and documented per the requirements of the Bentley Software Quality Assurance Procedures (D/N# QAP).
The Acceptance Test Set includes input files and full documentation covering a sampling of test systems and results documented from the Alpha Tests.
Although many program features are verified by the ATS, it should not be construed as being complete for testing of all program functions. Additional tests for specific program features are continually being developed.
This document contains information regarding:
§ System Requirements
§ Product Directory Structure
§ Installation Help
§ Documentation
§ QA Reporting Notices
You must have a DVD drive for product installation. The following prerequisites are required to run the Acceptance Test Set for Bentley AutoPIPE CONNECT.
AutoPIPE
A fully authorized copy of AutoPIPE Version 12.00.00.16 must be installed on your system prior to installing the ATS system files.
Processor
Intel Pentium IV or higher
Operating Systems
§ Windows 7 Professional or higher
§ Windows 8 Professional or higher
§ Windows 8.1 Professional or higher
§ Windows 10 Professional or higher
Memory
Minimum 2GB
Hard Disk
The uncompressed input files (.DAT, .CMB, .UNT, .SPC, .XML, and .OUT etc.) require at least 211 MB of hard disk space.
Input Device
Any industry-standard input device supported by Microsoft Windows.
Output Device
Any industry-standard output device supported by Microsoft Windows.
PDF Reader
Adobe® Acrobat Reader 7.0 or greater.
Before you install the Acceptance Test Set files, you should confirm that you have adequate hardware and software capabilities to execute the test samples.
1. From ATS DVD, locate and run the setup.exe to initiate the installation process.The setup program will guide you step-by-step to install the contents to the hard disk.
2. The default destination directory is "C:\Bentley\AutoPIPE CONNECT QAR v12\ATS".3. The input files will be placed in the specified destination and the previously verified output files(benchmark) will be placed in a directory named "OUT" located in the destination directory.4. Once all the files have been installed, the setup program will display the final dialog. An icon will be added to the program group allowing you to review this file at a later time.5. Select "Finish" to complete the installation.
Full documentation, provided in
pdf format is installed with the test files.
Adobe Acrobat ReaderDocumentation is provided in PDF files and can be browsed, searched, or printed with the Adobe Acrobat Reader. Information regarding the Adobe Acrobat Reader can be obtained from
http://www.adobe.com/.It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-12.0.0
Error reports are available with client participation in the "QA & Reporting" services. Monthly error reports, periodic compilations of all open errors for respective software products, and details of errors fixed through individual software releases are posted to a private QA&R Community under the Bentley Communities website at:
http://communities.bentley.com/
Notes for automated validation runs:
1. The printer configuration for the "number of lines per page" must be set to sixty-three (63).
2. Below given instructions/comments should be considered before executing the test runs:
a.
AutoPIPE CONNECT QAR build must be installed before installing the ATS.
b.
Desired AutoPIPE edition should be selected before execution of the ATS.
c.
In order to execute the ATS for a different AutoPIPE edition, ATS application must be closed and restarted.
d.
Before executing the ATS:
I.
Copy all the models and their dependent files (as mentioned in 'ap_ats.pdf') to a separate location on your machine.
e.
For each AutoPIPE edition use a clean set of models by copying back from the location where they were previously saved, as mentioned above.
If you have any questions as to the acceptability of the contents of the ComparisonLog file for QA validation purpose, please call Technical Support.
© 2019 Bentley Systems Inc., Legal NoticeU.S. Pat. Nos. 5,784,068 & 5,815,415 & 6,199,125
AutoPIPE ATS Install, License, and Run instructions
AutoPIPE Automatic Test Set (ATS) Release Notes
