| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Graphics |
| Date Logged & Current Version | June 2021 12.06.00.48 |
Dialog text dopes not appear correctly, shown below:
Why and how to fix the issue?
First close all AutoPIPE applications, then follow these steps exactly as indicated below:
Check following two settings, if different than recommended then set to recommended values and then check the impact on AutoPIPE. For steps see below screenshots.
Note: images assume using Win 10
a. DPI settings (Recommended = 100 %)
b. Unicode UTF-8 Language support (Recommended = Unchecked)
After making these changes, open AutoPIPE to see that changes fixed the issue.
