| Version(s): | All | ||
| Area: | Error | ||
The following error occurs when I analyze my model or review my results :
Error
E829-1: Incorrect model size in file
Static analysis results will be ignored.
OK
Error
E90-21: Analysis results do not exist
OK
what can be done to avoid this?
The results data currently analyzed has a conflict with existing data. Easily resolved by deleting the existing results database, reanalyzing, and reviewing the results grids / reports. Consider the following procedure:
Open the model in AutoPIPE.
Select Analyze> Delete Analysis Results ( see AutoPIPE help for complete details of this feature)
Select Analyze> All, check all boxes
Press OK button to complete analysis
Review the results with Output grids or Output report.
