AutoPIPE Connect Advisor Knowledge Map
NOTE: CONNECT Advisor is only available with AutoPIPE v11.1 through v12.5.
Open AutoPIPE CONNECT Advisor and select the Knowledge Map symbol, choose from drop down selection:
a. Knowledge Map
b. Learning Paths
Knowledge Map:
Select hyperlink below:
Pipe Stress Analysis
Select items below as needed:
Getting Started
Modeling Piping Geometry
— Setting Up Program Configurations
— Creating a New Model
— Creating Piping Geometry Part 1
— Creating Piping Geometry Part 2
— Reviewing Piping Model
— Modeling Piping Geometry PDF and Dataset Download
Model Modification
— Inserting a disconnected Segment
> Inserting a Disconnected Segment
> Insert Rotating Equipment
> Insert a valve
— Editing Operations
>Add a Valve Actuator
> Insert a Point along an Existing Pipe
> Copy  and Pasting Piping
> Rotating Piping
— Inserting a Pump part 1 (Rotating Equipment)
> Insert Pump using Rotating Equipment
— Inserting a Pump part 2 (Rotating Equipment)
> Insert Pup using Rigid Element and Allowable loads
— Reviewing the Piping Model and Running a Basic Static Analysis
— Reviewing Analysis Results
— Managing Segments
— Model Modification PDF and Dataset Download
Intermediate
Static Analysis and Loads
— Static Analysis and Loads PDF and Dataset Download
Spring Selection
— AutoPIPE V11 PDF and Dataset Download
Jacketed Pipe Design
— AutoPIPE PDF and Dataset Download
Vessel Modeling
Advanced
Dynamic Analysis
— Modal Analysis
— Response Spectra Analysis
— Time History Analysis Water / Steam
∞ AutoPIPE Water / Steam Hammer V11 PDF and Dataset Download
— Time History Analysis Slug Flow
∞ AutoPIPE Slug Flow V11 PDF and Dataset Download
— Steam Relief Lift analysis
∞ AutoPIPE V11 PDF and Dataset Download
— Harmonic Analysis
Non Metallic Piping Analysis
— AutoPIPE V11 Skills Assessment
Buried piping Analysis
Nuclear
Fatigue Analysis for ASME NB
Geometry considerations for ASME
Loading Considerations for ASME
Results Post Processing for ASME
Learning Paths
Select hyperlink below:.
Answering your CONNECT Licensing Questions...
CONNECT Licensing Overview
Watch 6 min video
In-Application Learning with CONNECT Advisor
Training - Webinar - Seminar - Conference - Learning - On Demand Learning - Product Training
